Old Aug 11, 2022 | 07:33 AM
zip439's Avatar
zip439
Default Re: ABS and BAS/ESP dashboard lights.
Originally Posted by shortspoon
I understand the bad battery being a possible cause of wing up but in this case it is a new 74ah Bosch. I have also checked the wiring to the spoiler motor for power which is ok and cleaned all its connections. The rocker switch on the dash has no effect on the wing but blinks consistently. The RCM is also new and having checked, the relays work as they should. I have changed the ABS module for another s/h unit but have not re programmed with my VIN, does anybody know if this is necessary?
The CAB (Controller Anti-Lock Brake) does not need any programing. I'm thinking that is what you refer to as the ABS module. It has a large electric connector on the side which is attached to an aluminum block with the ABS values and solenoids and has the steel brake lines running to the wheel calipers. Just be certain you have a CAB with the same numbers as the one you replaced.
Does your cruise control work?
