Old Aug 15, 2022 | 12:21 PM
ZERACER
Default Re: Charge System Error - Alternator?
The HI iol light is probably because they put a little too much oil in and when it gets hot, expands, it triggers the warning. If it is a bit high going uphill can also trigger it. Will it hurt anything? Probably not but it may be a bit irritating. As for why the charging light, I would look to see if they got oil in the alternator. Who changed you oil, a quick lube?
