Old Aug 16, 2022 | 09:49 AM
zip439's Avatar
zip439
Default Re: Charge System Error - Alternator?
A quick/easy alternator test: with car running use your volt meter across the battery terminals on the AC setting. You should not get any voltage. Something like .02 is okay it will bounce around a little but nothing much more. If you do show AC voltage your alternator is bad.
