intermittent Fault- turn key instrument panel lights up but no turning over of the engine just a click sound. This fault progressed to when turning the key it would stay in the start position with the engine turning over but not starting or starting and then stopping after a few seconds. Key needed to be turned back manually if it didnt start to stop the starter motor..
Hi after reading several threads I noted that there was an issue with dry solder joints on the circuit board of the ECU or RCU -relay control unit situated beside the battery under the black lid. I located and removed the unit and took it to a TV service centre to test the board and they found four dry joints- excellent.
Replaced board- still not starting and key remains in start position with starter motor turning over. GRRRRR!!
Any next step suggestions gratefully received
