Jimbo409
Thinking of buying a 2005 crossfire with 79000 miles
my questions are do all crossfires get the sticky key problem and what does it cost to have fixed
also do all crossfire have the rear window issues falling out
The forum usually advises to do it (then you'll have no problems if done correctly). I've never seen a post after someone successfully does the sticky key fix, have a problem afterwards. Many many have done it DIY, a few had a level of difficulty usually associated with a procedural or communicative difference. Also, it may have already been done if it was owned by a prior forum member. Best to download the 'sticky key' fix (latest one) from the document collection and read it about 3 or so times. Those that had no issues doing it indicated it was super easy if following the tutorial carefully. Good luck in your XF find!
