Old Aug 21, 2022 | 04:03 PM
zip439's Avatar
zip439
Default Re: When I put the parking a click sounds from below
Thunder, the parking brake is a cable that runs to the rear wheels. The parking brakes are drum brakes on the rear hub. You do not need a transmission mechanic. You should jack the car up and see if the cable is too loose, or perhaps it is not routed properly. Do the parking brakes hold the car from rolling on a hill? Do you hear a noise when the car is driven ?
