Old Aug 26, 2022 | 01:23 PM
GraphiteGhost
Default Re: 74mm throttle body
Many many years ago (in my signature, June 2012) I purchased one off Ebay, never had a problem. With 'used' ones you just need to make sure it not only looks good, but the 'ad' has Ebay's money back guarantee (as the term used denoted it works 100%). Only additional I have, follow the .pdf in the document collection & MAKE SURE the rubber gasket does not slip out of the groove during installation. I used a small amount of petroleum jelly to 'hold' it in place until mounted. If your careful, there will be no leaks from an improper seal of that gasket. There will be (in most cases) a relearning of the ECU when first started but that should go away within a few miles/starts/stops. If rough running still happens, you probably have a slight vacuum leak somewhere. Good luck!
