Old Aug 27, 2022 | 05:31 PM
richb55's Avatar
richb55
Default Re: ugh! crankshaft position sensor
Originally Posted by roychez
I was having an issue with starting my car it would start in the morning but after a short drive it would take several tries to get it going. I was told it could be the crank sensor so i replaced it. I drove it for a day with no issues then it the same issue resurfaced then the check engine light goes on ugh! so i get it diagnosed and the code p0341 pops up the camshaft position sensor. so I`m buying one tomorrow I hope this does the trick.
The question I have has anyone else have similar issues and what did you do to correct the issues.
I know this post is old. But my crossfire starts up and runs no problem. If get to my destination and try to start it again it will crank with no start
3-4 time an in the 5th time it starts right up. Sometimes it only takes two try’s. I have replaced both cam & crank sensors. Anybody else out here in crossfire world experience this
thanks in advance. Richb55
