ymatt
I have 2007 crossfire with custom radio. I have replaced the Infinity amp due to the amp got wet and out of order.
It sound a short time, but it got no sound by touching the wires.
I found that the orange/yellow color two wire were out of amp connector socket.
I would like to know how to connect the two wires to the corresponding socket pin.
If you have wiring diagram for the amp, it will be very helpful.
Thank you.
ymatt, I see at least two sets of wires cut in that picture, looks like someone has been doing some modifying here. Suffice to say it might be slightly harder to trace/rewire at least those two, and also replacing those two connectors you posted about being out of the connector (the connector you referenced). Good luck!
