dcskmail
Try the simplest first, re- tightening the valve cover bolts, they loosen over time: torque is 7 ftlbs If you do replace the valve cover gaskets it would be the perfect time to replace your spark plugs if needed, makes it a lot easier
Going to do that first this weekend. But need to buy a torque wrench that is capable of low torque numbers. Mine starts at 14.5 lbs ft. I'll see if that helps before tackling the valve cover resealing.
