larskeller
weather notice and tires.......sunday, sept. 25th. Weather forecast for fri-sun of dragon wknd is for rain all 4 days. So that means now it will probably be a beautiful sunny fall wknd! Hurricane ian track predicted ..tampa, daytona and from there up the atlantic coast of ga, sc, nc & va. Rain bands spin off may reach inland as far as tn. Inspect all of your tires to insure plenty of tread remain. Inflate to proper pressures when cold. Early mornings at fontana are often in the 50's. Your tire pressure will drop 1 psi for every 10 degrees in temperature drop (rule of thumb). Nitrogen filled not quite as much. Even 1 degree pressure change affects tire handling performance. If you don't believe that ask race car drivers, they change pressures by as little as 1/2 of a degree for changes in handling. Watch out for leaves in the roadways, especially when wet, loss of traction is instantaneous in the curves. Be safe have fun!
