Old Sep 25, 2022 | 06:07 PM
ZERACER
Default Re: Centre armrest won’t open
There is no air actuator in the console or armrest. It is in the trunk. You stated you broke a part, so I assume you know how to remove the center console, if not, use the search feature at the top of the page. After you remove the console, you will see the plastic tube that carries the vacuum to operate the lock. unhook it and suck on it to unlock the latch. Tape it off so you do not leak vacuum to the rest of the system and as long as it is unhooked, it will no longer lock or unlock. I assume you never viewed the instructions on replacing the cupholder ?
