Old Oct 13, 2022 | 07:56 AM
GraphiteGhost
Default Re: P0410 a new twist perhaps
[QUOTE=THETESTER;972968]
THe criteria that determine when the ECU will run the pump is not clear to me. I don't always hear the pump on startup.
Do you think it's a fair assumption that the pump would run on a typical cold damp British day ie low 50's?
On initial startup, yes. BUT if warmed up and not sitting for too long (where pressure may drop after a period of time), no. If you suspect a drop in pressure, then get the test done at the schrader port on the fuel rail. Otherwise, hunt and peck for a solution (used to be called and still is 'the shotgun' method), that usually costs a lot more in the long run. Good Luck!
