Glad the key worked out for you triplmmm
Cool vehicle dedwards0323, haven't seen one of those yet in person. Your vehicle most likely does in fact have a door lock. If you look underneath the plastic where the door lock would be, you should see a tab where your key can be inserted to pop the plastic cover off. This will be useful when the car's battery dies eventually one day. Below is a link explaining it in more depth. Mind to the tabs inside the plastic cover when putting it back on. They usually go back on with the side away from the handle first, and then the other side pops in.
https://www.vwgenuineparts.co.uk/vw_...nlocking.shtml
