Old Oct 22, 2022 | 05:58 PM
mrradio's Avatar
mrradio
Default Re: Again...how to secure the beige trunk panel
Perhaps they will break, but so did the originals. Fell apart or bent or missing. Too bad you have to go to such lengths just to inspect the air pump.
I love my Crossfire, but it is one thing after another. PS I drilled a one inch hole in the foam so I can see the drain hole without removing anything.
Tnks for the reply.
Update. The Amazon "Mercedes" clips are indeed crappy and break easily as noted by Ronman, but they do fit. I finally managed to get the panel in place after repeatedly snapping and bending the new clips. My only suggestion is to remove the seatbelt cover trim. That allows you to align the far left upper tab that pushes into a metal grabber clip at the window. Then insert the plastic clip below it, that gets you started. Regardless a real PITA, It fits securely now but I never want to do this again.
