Old Oct 24, 2022 | 11:03 AM
onehundred80
Default Re: Chrysler Crossfire Central locking - Locking but not unlocking with fob
Originally Posted by mrradio
I have a similar problem with my 04 coupe. Drivers door will not lock with the fob, but mechanism works ok with the key.
Locking with fob, passenger locks, trunk locks, gas filler door locks.
Now when you open the drivers door, the siren goes off. So I have to unlock with fob before opening drivers door. The car thinks Im breaking into it.
Diagnosing. Pump cavity all dry, no evidence of water ever. Pump seems to run much longer (30 sec) after each lock/unlock event. So I thought maybe a leak at the drivers door.
Investigating. Air lines run from pump direct to gas filler door, and with a tee from another line to the trunk
Lines remaining go to passenger side, presumably to the passenger door, and then onward towards the cowl and a left turn under the dash to the drivers side.
Line at drivers side is visible with an inline connector if you remove the kick panel. Helluva time splitting that connector. Sucked on line to door, holds vacuum.
So I'm at an impasse. Will make do locking with key until I get another brainstorm. Any ideas welcome
The drivers door has its own pneumatic circuit and is not connected to the passenger circuit or any other circuit.
The gas cap cover has its own circuit as well which is only activated when the car is locked from the outside by using the fob.
The passenger door and the lift gate share the same line.
The heavy black lines are the pneumatic lines, the other lines are wires.
This diagram is for the coupe only, the roadster has a pneumatic line for the console lock.
This photo shows the three pneumatic lines rising from the CLP/SSM on a coupe, the right hand line rising and going up behind the roof liner is going to the gas cap cover and the line rising from the Tee fitting on the passenger door line goes to the Lift Gate lock. The two lines disappearing to the left go to the passenger and drivers door locks.
