Old Oct 24, 2022 | 04:18 PM
mrradio's Avatar
mrradio
Default Re: Chrysler Crossfire Central locking - Locking but not unlocking with fob
Hi roman, yes I meant the A pillar. I tapped in at the kick panel. I followed the yellow lines, from the pump they go up to the window area and head down to the floor of the passenger side behind the seat. The passenger line re-appears centre console footwell, and right turn to passenger door.
I can only presume the drive'rs line is under the console and then a left turn to the driver door.
I tried several routes for the new line. The only practical DIY route was to follow pump lines to passenger floor behind seat, then along the back wall tucked in under the upholstery, over the hump behind the console, under the drivers side back wall, then removing drivers trim plate, tucked in behind the carpet to the kick plate.
All done and working fine. The air blue air line I used, I got from amazon it is marked TPU0604 HFW002 6 x 4 mm. I had purchased it previously to run a lock release line to my lift. It fits perfectly tight over the yellow Crossfire air lines
finally back together at rest in my man cave.
