ws6vert...
I think it corners a little better then stock, probably because of the lower center gravity, but its not a huge difference.
It just looks cooler for the most part.
Jenky...
I got the adjustable camber arms off ebay. They are made for Mercedes cars. They are not easy to install because they come with standard size rod ends, and the car has metric bolt holes. I guess no one sells metric rod ends.
So I had to slightly drill out the metric holes in order to use standard size bolts. Not too big of a deal, it was just very hard to get at with a drill.
Bullseye...
Thanks for the props,
Actually I might be going to Byron this weekend, we'll see.
Porterhouse...
All the Sprint Booster really does is make the gas pedal much more sensitive.
So in reality, it doesn't make the car faster because it doesn't make hp.
It does feel faster though, because you barely push the pedal and you take off spinning the tires if your not careful!
