Re: OEM amp needed
pizzaguy
Make sure that, not only is the fused B+ to the amp OK, but that the enable line is going high when you turn the AM/FM head on. Measure this at the amp's connector, not up at the head.
THis was an issue on one of the Facebook pages last week.
Thanks very much for this. Getting battery voltage on both b+ wires. But 6.3 on the enable signal wire when ignition turned on. Do you have any more detail on what might cause the low power and how to fix it. We have swapped in a known good head unit too and no change. It looks like power is getting to the amp but there is no measurable output from the amp. We have already replaced the amp once as well with no change. Going to try a third amp when it arrives.
