Old Nov 21, 2022 | 05:01 PM
onehundred80
Default Re: BAS-ESP connector
Originally Posted by Phil
Hi gang,
Today I worked on a project, replacing the wiper module and wiper arms. Mission accomplished. However, when I was removing the cowl grille drain, a connector came unplugged (see the attached picture). I could not find what it connects to. The engine runs, however, the BAS/ESP indicator on the dashboard stays ON (wasn't doing that before I did the wiper repair). I've gone through the service manual, but can't find a reference to where this connector attaches to. The reference to the drain is on BR-43 of the service manual. The wire goes through the same rubber grommet (cowl ledge) as the wiper motor harness. Any ideas what the connector attaches to?
Thanks for the help.
Connector near the cowl grille drain (BR43)
There are connectors under the cowl that go to the windshield washer heaters and the siren.
