Old Nov 21, 2022 | 05:03 PM
GraphiteGhost
Default Re: BAS-ESP connector
Originally Posted by Phil
Hi gang,
Today I worked on a project, replacing the wiper module and wiper arms. Mission accomplished. However, when I was removing the cowl grille drain, a connector came unplugged (see the attached picture). I could not find what it connects to. The engine runs, however, the BAS/ESP indicator on the dashboard stays ON (wasn't doing that before I did the wiper repair). I've gone through the service manual, but can't find a reference to where this connector attaches to. The reference to the drain is on BR-43 of the service manual. The wire goes through the same rubber grommet (cowl ledge) as the wiper motor harness. Any ideas what the connector attaches to?Thanks for the help.
Is there a siren at the center of the cowl? If not, that MIGHT be the siren cable. The siren has three wires at the plug end. Good luck!
