Thread: error p0106
Old Nov 26, 2022 | 07:31 PM
mariontr's Avatar
mariontr
Default Re: error p0106
Originally Posted by X-fired
My MAP hose is also looking fragile so I'd like to replace it. Were you able to replace yours? Any details? Thanks.
I was able to replace mine along with the hose that connected to it. It was fairly easy to locate see the post from BMWbiker, Toolman and zip439. I was able to find the MAP on Amazon for Mercedes
(Bosch 0261230189 (Bosch 0261230189
. The hose that I used was
HUICONIC Blue Color 5FT Length High Temperature Silicone Vacuum Tubing Hose (5FT X 3MM(1/8") HUICONIC Blue Color 5FT Length High Temperature Silicone Vacuum Tubing Hose (5FT X 3MM(1/8")
from Amazon also. Hope this helps you.
