Old Nov 28, 2022 | 10:26 PM
Ronman's Avatar
Ronman
Default Re: Door not latching completely
Originally Posted by svtmerc
The drivers door will only partially latch, if you close it, then bump it hard with your read end it will fully close and latch. The latch on the door and the striker in the jamb do not appear to be adjustable, and the door doesn't seem to sag much like if the hinges were worn out.
Is this a relatively common thing on these? I couldnt seem to find anything while searching the forum here.
The striker is adjustable, there is a torx screw above and below. You would have to loosen both screws then you can adjust it accordingly, you are supposed to use a special tool to center it. If you have the time to play with it, you might be able to get it to work. If you don't know what you are doing then you might make it worse and the door won't close at all.
