Old Dec 2, 2022 | 08:54 AM
BigRands's Avatar
BigRands
Default Re: Remote won't Lock/unlock door
Originally Posted by zip439
The system works via air pressure/vacuum from a pump located in the right rear of the car. You may have a broken air line if the doors are not locking unlocking with the dash mounted switch. The pump (CLP/SSM) is integrated into the security system. You access the pump by removal of the foam pieces and the felt side pieces below the carpet.
Use the search box in the upper right corner of the forum with the google option for more info. and click this link: CLP/SSM info
Thanks for the reply. The button inside does indeed work. Which is odd. The button works, and when i press the buttons on the fob, the lights even flash, but just the locks don't work when pressing fob buttons.
