Re: What did you do to your Crossfire today?
No. They did not rub on that car. My car uses lowering springs and that's why its rubbing. To be fair, the stock wheels and tires rubbed too. This wheel and tire package is 2/10ths of an inch larger in overall diameter compared to the stock setup so that's as close as you'll get to factory sizing when dealing with 19- and 20-inch wheels. Im swapping my lowering springs out with another set with a higher (stiffer) spring rate. My hope is that it won't rub as bad, if at all.
