Old Dec 2, 2022 | 03:21 PM
Astrofriend's Avatar
Astrofriend
Default Re: Spring pad shims
Hi,
The car has been smashed in the front, no traces of that today, but ofcourse it can be related to that. It looks to be half the difference compare to before I changed the springs, pads and bushings. One bushing was very bad, so I think it was that which cause the difference partly. But I must take out the car and park it on flat surface and redo the measurement. I just waiting for the snow melt away. One more thing, I can see that they have tried to adjust the toein/out at the rear with the defect bushing, now I can do a new adjustment.
The spring pad was 5 mm from the beginning which I didn't know before it was taken apart, the new pads are also 5 mm. So that's correct.
The new yellow bushings looks to fit perfect, much stiffer compare to the old standard rubber bushings, Anyone else who has these bushings installed ?
I know the lower front bushings are very soft too, I change them later and also the springs and pads if I can find them. Anyone know the part number of the front spring pads ?
Lars
