Old Dec 2, 2022 | 05:31 PM
zip439's Avatar
zip439
Default Re: Spring pad shims
Lars, read again post #4 The front 5mm pad should be A210 321 01 84.
When you check the toe adjustment check the thrust angle. It should be easy enough with laser adjustment at a good shop. That will let you know if the car is straight after the front smash damage was corrected.
