Old Dec 2, 2022 | 05:44 PM
Astrofriend's Avatar
Astrofriend
Default Re: Spring pad shims
Originally Posted by zip439
Lars, read again post #4 The front 5mm pad should be A210 321 01 84.
When you check the toe adjustment check the thrust angle. It should be easy enough with laser adjustment at a good shop. That will let you know if the car is straight after the front smash damage was corrected.
Yes I know about thread no 4 but was not sure about the thickness in the front. Thanks, now I know which to order, 5 mm and got the part number too.
Lars
