Re: No Crank / No Start (Not RCM)
Sorry for belaboring the point, but I haven't been able to get to removing the SKREEM and ECU until tonight. After re-reading all of the posts, before I remove parts I just want to check if my symptoms still indicate a SKREEM problem. About 4 months ago, I pulled into my driveway and turned off the car. The next day I tried to start it, and got no crank - dash lights went on, windows worked, door locks worked, but no crank. After reading some of the suggestions, I left my key in for more than 30 seconds, the fans didn't go on, and still no crank. Tried the quick key thrust, nothing. Disconnected the negative terminal for a day, put the battery on a charger. Connected the battery again, the rear spoiler went up, still no crank. Tried to move the shifter out of park, won't move even with the key in the ON position (is that also a symptom of a bad SKREEM?) and the rear spoiler won't go down even when the key is in the on position. Starter and solenoid are good - jumped the pulse module. I do have rodent problems - the recent issue was they chewed through the windshield washer motor cable, and the reservoir sensors located under the battery (could they have chewed something else that is preventing starting?) I guess it can hurt removing the security program, but if I don't have to spend $450, I don't want to.
Thanks in advance,
-Jerry
