Old Jan 1, 2023 | 11:20 PM
SD Crossfire's Avatar
SD Crossfire
Default Re: 6 Speed Oil Change- HELP ! ! !
Originally Posted by trshman
I didn't know the manual was a Chrysler unit. As I originally said the car is a loaner. Like you said changing the oil should be a no brainer. If I had a lift I'd do it myself. My VW mechanic said he'd do it if I was willing to wait a couple of weeks, which I am. There's always a backlog to see him. The car's got 120K plus miles on it and I'll bet it's never been changed, so improvement or not, it needs it. Using Redline in my VW 5 speed made a noticable improvement. Much smoother, and easier shifting. I definitely understand the"clunkier" description so changing the oil may/may not have an improvement but it's the least I can do to thank her for lending it.
It's not, the NSG370 was sourced by Mercedes and built at the Stuttgart Transmission Plant. It's also used in Jeeps Wranglers of the time along with a few other Mercedes models.
Originally Posted by dcskmail
I've changed my 6 spd oil and really hasn't made a big difference especially from 1st to 2nd, bleeding the clutch system and slave seemed to help but you may as well also bleed the brakes as both systems share the same fluid
Which fluid did you use? It doesn't use standard gear oil, the only fluid you should be using is MS-9224.
