Fuel system rebuild
I am having trouble starting and am thinking fuel pump is going bad. It cranks longer than normal before firing up. It seems to start quicker if I cycle the key a couple times. Even after cycling the key, I can still squeeze the fuel line in my fingers, so Im guessing its not building much pressure.
In looking at the fuel line, I noticed that all of it is rotted. Has anyone replaced the entire fuel line? Can you get the lines that have crimped on fittings anywhere?
