Old Jan 3, 2023 | 01:19 PM
Ronman's Avatar
Ronman
Default Re: What causes a Crankshaft Position Sensor to fail?
Originally Posted by BobG
Here is a photo of my original crankshaft position sensor after removal sitting in the box from the new CPS:
Notice the crud on the metal at the end. (Sorry, forgot to take photo of new sensor with its spotless end; didn't want to remove it from engine.)
If I were to clean that surface, would this CPS operate correctly? Or are CPS failures due to internal breakage?
Thanks
The heat from the engine eventually affects it. I change mine out every 4 years as preventive maintenance.
