Old Jan 9, 2023 | 05:51 PM
Romad's Avatar
Romad
Default Re: Crossfire won't start
Originally Posted by ZERACER
Point being, so many just check the solder joints, as time and milage take their toll, the relays themselves pit, burn and just wear out. When DJ rebuilds them, he also checks and replaces the relays as necessary.
I've been going thru some similar no start problems. If it were mine and suspecting RCM I'd buy one, as I did, and if it doesn't correct the problem you will at least have a spare because sooner or later it will go bad. IMO Pizzaguy is correct about not taking it to a dealer. They hate working on them and, and usually won't, will charge you a fortune and do nothing. Right now on Amazoo, they have RCM's with a PN: RY1562 for $122. It also says free return! Might be the best money you've spent in awhile. Just a suggestion!
