Old Jan 14, 2023 | 05:16 PM
Buck62's Avatar
Buck62
Default Which ATF Fluid to use??
My trans has a small leak that seems to be coming from the electronic connector.
I already have the OEM Mercedes connector, based on the info I've read here.
I also have the instructions based on a thread here, the actual service bulletin, and two videos saved.
I'll probably need to add a bit of trans fluid after the swap... right?
I've seen several different suggestions here, and they vary by brand and number.
Based on those suggestions, (and what NAPA and Amazon suggest) I've narrowed it down to the ones below.
Which one of these would work? Any of them?? All of them? Thanks in advance.
