Old Jan 18, 2023 | 04:25 AM
Viper-666's Avatar
Viper-666
Default Re: No Crank / No Start (Not RCM)
If it cranks every time, than it isn't a Skreem issue. So test if the ignition and the spark plugs are working. Also if the fuel pump runs. If both works the engine have to start. If you have no ignition it could be a bad camshaft sensor. Please use only Mercedes or Bosch as replacement.
