Old Jan 18, 2023 | 06:03 AM
  #60 (permalink)
AlCapone's Avatar
AlCapone
Default Re: How To: Replace the Washer Reservoir / Tank / Bottle (with pics)
Hi Folks. The windscreen washer pump/motor on my coupe doesn't work - no whirring sound, nothing. The wipers work, as does the headlight flasher (fed via the same fuse, according to my Owner's Manual) so not the fuse? Before I embark on removal of the reservoir to investigate, any other suggestions/short-cuts? I should also point out that the Low Washer Fluid Level warning light has been on since I bought the car - I thought it might be due to the dreaded cracked reservoir but I poured a couple of litres of fluid in yesterday and it did not start leaking/overflowing until halfway through the third litre. However, the warning light stayed on....but I did not actually start the engine. Maybe the reservoir is OK?
