dcskmail
Wheel Hanger Alignment Pin Guide Tool - Metric 12x1.5 - Mercedes Wheel Mounting Guide Bolt - Pack of 2, $10 amazon
This is the best idea imho, fit the wheel to one stud and rotate the wheel until it lines up to the location diameter on the hub. Keep the minimum gap under the tire. Or use two bolts one an inch or so longer than the other and both with a nice gentle taper on the outside end.
Remember to clean the location diameters and add a spot of lithium grease to them to retard any corrosion. Clean the faces where the bolts go through.
