pizzaguy
That module is home to nothing more than five relays that supply switched power (under command, primarily, of the ignition switch) to the fuel pump, secondary air injection pump, horn, traction control system and the Power Train Control Module (PTCM/ECM).
The relays themselves can fail, but most often, the issue is fractured solder connections on the board where external connector pins attach.
Thanks Pizzaguy! That's a great informative picture of the relays and what they control!
