Padgett
Have a similar problem, key locks and unlocks driver's door only. With key on does the console switch lock and unlock all ? If so we have the same issue. Has anyone worked on the SKREEM ?
no one has worked on SKREEM, with key on the console switch won’t lock or unlock anything. When the top of the console switch is pressed, you hear the air pump operate, but nothing happens, when pressing the bottom of the switch, nothing happens. Have taken door lock mechanism out and there are no electrical wires going to it. So there is no way the key is able to unlock the other door, trunk. ( have seen on a YouTube video on a left hand drive model that it has a electrical wire connection) Maybe the low volume RHD model’s weren’t wired up for it? Anyone have any thoughts? Cheers Frank
