SD Crossfire
Thanks for the suggestion, I took a look and the rubber seems to be in good shape and well seated, but I may put some light grease around the edges just in case. I totally agree the leak can come from some far away location, hopefully will figure it out soon, it's expected to rain soon.
The light grease won't hurt. How does the weather stripping look? Is it damaged anywhere? Also is your window "adjusted" right. I know these cars had issues with wind noise and it was due to the window not being "tight" and creating a seal.
What you could do is sit in your car and have someone hold a garden hose to your car and/or drive through the car wash and see if you can find where the water is entering the car.
Hope you find it. I know water in the interior can be a challenge to locate where it's coming from.
