Old Feb 28, 2023 | 03:40 PM
onehundred80
Default Re: Door lock latch actuator causing multiple issues.?
YOu seem to be changing the definition of "Manually" and using the word twice. Very confusing. I can't follow exactly what is going on.
Obviously manually means turning the key by hand. I agree that I am a bit confused as well.
Problems like this are simpler to read when shorter sentences are used like a bullet pattern.
Did this happen all at once or over time?
I did not think that opening the car manually involved the SKREEM at all.
The door can be opened without the door switch connected, nothing else would open or close though.
That is my understanding of the system.
My problem is the opposite of this problem, my dash open/close button does not work, but everything opens and closes manually
or remotely.
