Old Mar 1, 2023 | 07:50 AM
  #66 (permalink)
AlCapone's Avatar
AlCapone
Default Re: How To: Replace the Washer Reservoir / Tank / Bottle (with pics)
With reference to Page 8R-5 of the Service Manual: Washers Inoperative - Continued. Section 2. Measure Multi-Function Switch Voltage. This instruction refers to the Washer Pump Motor Connector and the diagram appears to show a 2-pin, oval shaped connector. If this connector is the one that I think it is (see photo to follow below, if I can post it successfully!), how on earth am I supposed to even reach it, let alone separate the two halves and measure pin voltages. Note that my car is a right-hand drive model for South Africa, so the under-hood layout may be different to the US models.
