LagDan
Search . . . it's the vacuum line comming from the engine and going to heater control.It operates blend air door for the AC controls and vents.
Daniel
Hi Daniel,
Thanks for the info. If it's a vacuum line from then I'm glad I re-attached it. Not sure I did a great job - I got some plastic tubing with a slightly bigger ID than the original, slipped it over and use shrink tubing to seal it. Hopefully, that keeps the vacuum intact, otherwise, I guess the engine will run rough.
-Jerry
