Re: Brake light malfunction
Hi Pizzaguy
ah apologies I should have taken a pic before replacing but the chain of events is something like this…
I had a brake light malfunction and I took out the ICM for testing.
The ICM has a large grey harness which opens by pressing a clip and pulling upwards, ditto a black one, a purple small harness with top and bottom clips and a really small black slide out at the end.
The clips on the purple one are really brittle and the top one snapped but I thought I had secured back in place using only the lower one. After a few days I noticed that the turn signals, dash lights and console lights weren’t functioning. I went back to the ICM and noticed that even a slight movement in the purple harness could make them malfunction. A little drop of glue at the top of the harness, held in place with a vice until setting was enough to hold it more securely.
If anyone has the same symptoms, the purple harness would be the place to start. I couldn’t determine if there was a fuse associated with that system.
