Old Mar 15, 2023 | 10:54 AM
zip439's Avatar
zip439
Default Re: Problem with spoiler
Originally Posted by CurtCrossfire
I disconnect it and cleaned all the connections, it went up past 60 but doesn’t go back down, the button doesn't work either and no light at all when I press button
You cleaned what? Did you have the plastic off of the hatch so you can get at the motor? Did you inspect the limit switches? Check the linked thread for additional info. The limit switches are Crossfire specific parts so they are no longer available but read down to post 15 for part replacement and post 18 for a "fix", spoiler info/help
I'm not sure that you may have a problem with a wheel speed sensor. A good scan would help with that possible issue.
Good Luck
