Old Mar 19, 2023 | 10:19 AM
richb55's Avatar
richb55
Default Re: Snapped the bolt on my transmission connector adapter
Originally Posted by zip439
I would pull the battery out and the plate it sits on. There is a vacuum hose under there that goes to the A/C blend door I believe. It could easily have been rotted out from the battery setting above it and could possible be a path for water to get into your passenger compartment.
Now that you have blown the drain lines out I would run water through them to be certain they drain properly and be sure the small rubber guard directly under the hinges is sitting in there properly.
good info. So far so good 👍
