Old Oct 2, 2006 | 05:33 PM
  #60 (permalink)
woody's Avatar
woody
Default Re: Baseline Dyno Run Results
Originally Posted by golfdude
Hmmm...Today on the dyno I got about 195 lb/ft torque to the wheels with the rear speed sensors disengaged. My car is stock. On Friday I will be playing with the car once again to try to disable the limiter to go up to 6,100 ish rpm. The limited stopped at 4,200 rpm. On the first run, with the rear speed sensors in tack, I lost 20 ish horsepower.
Hey Golfdude, did you just pull the rear speed sensor connections at the wheels and get a full redline run? Mine will just throw a code and gives me a 5,000 rpm limit if I disconnect any or all of the sensors. Is yours a 6 speed or an Auto?
EDIT - Also forgot to ask if it was a belt driven 4 wheel dyno like TimeLord found?
