The idler pulley on my 2004 disintegrated this afternoon and serpentine belt shredded. I've got a new pulley and belt on order.
To install the serpentine belt, the shop manual says to release tension on the tensioner by turning the 17mm cast bolt counter-clockwise and then lock it in place with a 5mm pin. Some observations:
- It's difficult to move the tensioner much with a standard 8-in socket wrench. I can move it well with a cheater pipe but it limits my range of motion.
- The tensioner cylinder makes quite the squeaking noise when it moves.
Should it be that difficult to move? Have any of you experienced a noisy tensioner cylinder?
I think I need to rotate it more so that the groove on the tensioner lines up with the hole in the case. Is that correct? That's as far as I can move it without a cheater pipe. I could try a shorter one.
Thanks.
Rotate tensioner until blue oval lines up with red arrow?
