Old Mar 24, 2023 | 10:01 AM
zip439's Avatar
zip439
Default Re: Shift Lever Assembly switch?
Originally Posted by jokersxf
Lots of great info and discussion. Trying to keep the shot group tight.
  1. Try PizzaGuy's parking light thing.
  2. Pull cowl and windshield wiper blades to check drainage and clean up like zip says.
​​​​​​Should I go ahead and pull that passenger carpet to see if there is damage around the TCM area?
Manual says to check and reset communication with drbIII if there is a CAN communication failure or no responses. 8E - 34..... Seems to be similar TS steps for most of the sensors and CAN system that call for drbIII.
Codes present with obdII (P2300)(P2313)(P240c)
Thanks again for all of the help and support. So awesome.
Yes lift the carpet in the passenger side foot well. If you find water intrusion it is likely the cause of your CAN BUS problems. pull the electrical connectors and inspect for corrosion. It is an easy job and you will learn a lot about the layout of your car.
