Old Mar 27, 2023 | 07:25 PM
1NAR's Avatar
1NAR
Default re: Supercharged M112 Engine
It runs and drives down the road! I got actual block off plates for the SAI from VRP and only have 2 codes for EGR and SAI (wow?! I did it right the first time???) then after a small test drive I noticed it boggs down at 2.5k rpms if I mash on the throttle from idle, and if I press it will very slowly climb past it. After pulling the codes again I found P0101 or MAF Range performance. So now I'm doing research on what I can do whether it's an ECU voltage or maybe I can swap my MAF with a different version/part number. This is just a small update letting you guys know it's running and meandering down the road (and yes there's already ALOT more power from what I can feel)
